What is the quickest way to bridge between multiple surfaces. I’m trying to avoid duplicating each edge and lofting between them manually.
Thanks in advance.
George
Thanks in advance.
George
Hi George - DupBorder, assuming these strips are joined polysurfaces, hide the strips, and loft between pairs. Does that do it? If the gaps are planar - no gap in the vertical direction - then you can Cap the strips (if they are closed, it looks like thay might be) then BooleanUnion all the resulting solid slices.
