Bridge panel with triangular panel B issue
I want to make birdge panel with triangle Panels B (Lunchbox) but in a specific section UV gap become unbalanced.
what if I want to make with an even panel shape?
I will upload my Gh, rhicno file.
thank you
250908.3dm (18.9 MB)
250908.gh (51.2 KB)
It’s simply because you are dividing a single curve on the “inside” of the track and using those divisions to drive the outside as well. When you have a tight bend, the inside stays well divided while the outside gets stretched. You will have to make the two sides as separate objects to get the desired result.
