Bridge Not Working on Sub D Edges— Rhino Newbie
Hello!
Rhino Newbie here, Having an issue with bridge not working on two edge selections that are sub D shapes.
When I select the second edge loop, it keeps asking to select the second edge loop in an infinite loop.
Feeling stuck, or does anyone have any solves on how to connect the two edges?
Hello- the number of edges needs to match on each end of the bridge - there is a command line message that may be scrolling up out of view.
Thank you! Is there an easy way to reduce the number of edges?
Cmd+Shift+double click an edgeloop and use the Delete key.
