I’m trying to follow along with Brian James/ tutorial on building a fork in SubD. I can’t seem to get past the initial Bridge command connecting the tines. The software selects the edges of the surfaces fine, but then does nothing when I click Enter.
One thing that is not very clear in that part is that for Bridge, you select one set of edges, enter and then select another set - so you cannot see it but there is an Enter pressed between the two edges that are bridged.
I tried the Ctrl/Shift while rotating technique that Brian recommends but never got it to “snap into an ortho view” as he indicates will happen when you get close to the view orientation. Is there another trick I’ve missed here?
It was at 4:20. I also noticed that when he thickened the fork at 4:00 the tips of the tines seemed to go to perfect three dimensional points. It wasn’t clear to me how that happened.
Could we talk over the phone? I am so frustrated. Now nothing is working as in the demo. I was having trouble with scaling the handle so I went back several steps to start over. Now all I can do is bridge the tines and extrude them back. When I try to scale the area behind the tines, (2:18), it scales all of the tines instead of just the edge/transition area.
The reason I backed up was that when I thickened the plane to make a solid, I did not get soft edges as Brian’s demo shows. I also can no longer recreate the dishing step, (4:55). It now bends the entire fork rather than just rotating the selected points.
Below is a picture of the first fork I created from the side view. You’ll notice that the ends are quite square. This was done using the SubD surface command and then offset solid just as Brian indicates around 3:55. You’ll notice that there are no soft edges and neither end comes to a point or radius as Brian’s model seems to.
I think I got most of it sorted out. Not sure why but when I offset the surface to thicken, it did it with creased edges. I had to go in and manually remove the creases. Still not sure why the view is not auto-snapping in and out of the nearest projected view.
Check that SoftTransform isn’t enabled if you see scaling impacting more than the area of sub-objects selected. Run SoftTransform with nothing selected to check if it is enabled as the state persists.
It is true that OffsetSubD will crease the edges and you need to run RemoveCrease to soften them.
To snap to an ortho view in Perspective start rotating the view and then while still rotating it, press ctrl+shift (cmd+shift on Mac) and you’ll snap to the closest ortho.
Can you post a link to the video you were following please, I think I’ve made a few using a fork as a subject and I want to be sure I know which one you were trying to follow.
