On The Mac, while the Bridge controller dialogue is open, the viewport manipulation is frozen, [at least when used with 3DConnexion] .
So for example, if one started the command when the geometry is in closeup in order to correctly selects the edges, it is difficult to see the bridge desired shape without the ability to zoom out and perhaps rotate the view for a better angle.
This appears to be due to the 3D Connexion device needing focus on the viewport not the dialog during Bridge. Click in the viewport and it will work again. I think it is something we should be able to fix… this doesn’t happen with the BlendSrf dialog for instance. Filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-57410
