I think this is an important one.
We need to be able to create a bridge between two faces and not only between edges.
TSplines had this possibility
Even better would be to be able to select multiple faces
Stay safe
Joao
Stay safe
Joao
Hi Joao - it is currently possible to use faces (and even multiple faces) as input for the Bridge command but you need to pre-select the faces. Allowing post-picking faces is on the list as RH-57203.
That said, could you try pre-selecting and see if that is the expected behavior?
Hello Wim,
I understand what you mean, and indeed if I pre-select the faces I want to bridge, the bridge command works fine.
The problem is that no faces option is mentioned in the command line, only edges or edges loops. The option to select faces [Bridge Faces| shoud be presented when the command is started otherwise how would one know that a bridge can be made between faces ?
Put in another way, the user should be able to choose between edges and faces in the bridge command
Hi - the issues that you mention are indeed the things that are on the list to be fixed in RH-57203.
Great !
Joao
