_bridge BUG with project on, WISH closed loop jump to second edge
the interface for the _bridge command could be improved:
there is a small bug - if the project option is on, adapting the Alignment / direction does not work - therefor the interface should ignore the project option
wish:
with pre-selection i can select two closed edge-loops, call the command and bridge will connect them.
with verb first / nothing selected the user is asked for first loop until pressed enter.
then for the second loop…
for me the expected behaviour would be, to step to “second edge”, as soon as a loop is closed.
the behaviour should be consistent to _blendSrf
THANKS - kind regars -tom
I agree-
https://mcneel.myjetbrains.com/youtrack/issue/RH-64177
thanks … great to see that a 3 month old post is still getting attention…
we try our best my friend…
