Brep.UnjoinEdges - clarification?
What does the last line mean as far as output? Seems a bit confusing.
Seems to indicate the input brep is not modified, how then do I get the brep with the unjoined edges?
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_UnjoinEdges.htm
Edit - a small test here indicates that the original is not modified, but the return is indeed the modified brep(s). That last line in the help doc just seems very non-sequitur…
