Starting from srf A I obtain srf B by using two loft commands and dividing the remaining surface with the outline curve of the first loft.
Once I try to convert the merged Brep into mesh just doesn’t work. The error is referred to the trimmed surface.
Please could someone explain why i’ve got this issue?
Hi Wim and thank you for the reply.
So the trimmed surface is the problem of that specific component. I tried without the latter and the components both work.
Yes of course that one is clear.
I was referring to the second point about the difference in the behavior of the MeshBrep and SimpleMesh components with Weaverbird’s Catmull-Clark subdivision.
MeshBrep returns less smooth geometry with the same parameters…
