Brep split with curves problem
In rhino 7 I made a python script to splits a surface with several curves.
When I use the blue curves in combination with the other curves the split will go wrong and one piece of the surface disappear.
It seams that the brep exists.
But when I add it to the document the guid “00000000-0000-0000-0000-000000000000” is created.
brepsplit.3dm (2.4 MB)
brepsplits.py (653 Bytes)
before the split
After the split
import scriptcontext as sc
from Rhino.Geometry import Curve
from System.Collections.Generic import IEnumerable
from System import Double
tol=sc.doc.ModelAbsoluteTolerance
brepID=rs.GetObject("Select surface",8)
crvIDs=rs.GetObjects("Select curves",4)
crvs=[rs.coercecurve(crvID) for crvID in crvIDs]
brep=rs.coercebrep(brepID)
splits=brep.Split.Overloads[IEnumerable[Curve],Double](crvs, tol)
if splits:
    for brep in splits:
        splitsurf=sc.doc.Objects.AddBrep(brep)
        print splitsurf
        rs.MatchObjectAttributes(splitsurf,brepID)
    rs.DeleteObject(brepID)
sc.doc.Views.Redraw()
00000000-0000-0000-0000-000000000000 == System.GUID.Empty - i.e. the geometry produced is invalid or absent and as such it could not be added to the document, so an empty GUID is returned when trying.
This appears to be a bug in Brep.Split() in V7, the code works in V8 and returns 4 surface pieces.
Ok thanks one reason more to change to version 8
