Brep Planes not in the right "order"
Hello, can anybody help me, I can’t seem to find the problem.
So I tried to build a parametric bench, an when I use the brepframes command everything seems to be in the right order. But as soon as I add the Brep/Plane the division is all over the place.
Thank you very much
Attach your file.
Bank.gh (10.5 KB)
Internalise your curves:
A moment later:
I’ve built my own scenario.
Everything seems to be correct.
You forgot that plane may cut curve in more than 1 place.
Thank you very much , this is how far I got. What is the panel in the upper List Item called?
Bank.gh (13.9 KB)
it’s just a simple text panel with 0 and 1 values just to show they are coplanar with the first cutting plane.
Sorry to bother!
I just can’t seem to make it work with the text panel (it looks different), or I’m not using the right one.
I internalisied the data, maybe you can find the problem?
Bank.gh (18.1 KB)
Okay I found the Problem and converted the text to number. But the lines are still moving into the bench, like the first problem :confused:
11.gh (17.9 KB)
thank you very much, that helped
