I’m a R3D 6 and Grasshopper’s newby and I’ve encountered a bug when I’ve tried to generate Brep sections through a loft. When a divide the polyline, its direction is flipped at the top end of the loft.
Thank you in advance for your help.
Hi Maxime - I see this, thanks - and I don’t have an explanation… But I’ll add it to the bug pile. The regular Rhino Contour
command does not flip the end one as far as I can see.
https://mcneel.myjetbrains.com/youtrack/issue/RH-51748
Hi Pascal,
Thanks for your feedback. I will have a go with the contour command and let you know.
Max
