When single-picking the 2 breps in BooleanFail.3dm (322.3 KB) for
_BooleanUnion, _BooleanDifference, _BooleanIntersection, _BooleanSplit, and _Boolean2Objects,
the order of selection affects whether the operation passes or fails in V6 and V7.18, but the operation is always successful in V5 and the WIP.
Hi Steve - my guess is that will not happen - just a guess, but I suppose the developer felt the fix was large or involved enough to be risky in V7. That said, I do not know if there is even a specific fix that handles this or it just works better as a result of fixes elsewhere…
Yeah… the edge tolerances are higher than file tolerance (What command) , I suppose that is at least part of the problem - testMarkOTEdges finds that edge as well, where the intersection is split up.
Just in the name of science, I merged the two fillets along the bottom of the red object - the edge between them is right on that green object intersection - and now the BU works in both directions.
