BoxEdit Position on Individuals (feature request?)
would be nice to have ‘Position’ work with ‘Transform objects individually
(so you can ground all floating objects at once, for eg, )
position_transform
Hi Yelen,
Just in case you don’t already know: In the absence of what you are asking for, select front or side viewports, select the objects (if not already selected) and type
align b 0
and press Enter or spacebar to place them all on the xy plane at z=0. If you want them at a different height, you can select a point with the mouse instead of typing the zero (or type an xz or yz co-ordinate).
Regards
Jeremy
rgt! in short of that direct option, Align Tools are def gd alternatives
thnx @jeremy5
