BoxEdit does not seem to update when working with block instances. Any ideas?
Hi Ryan - that should work at least for rotation, position, and uniform scaling, I would think. I’ll get it on the pile, thanks for pointing it out.
https://mcneel.myjetbrains.com/youtrack/issue/RH-37541
Excellent, thanks Brian…
I have noticed that BoxEdit takes a little bit longer to load in comparison
with RH5 - just an observation.
Kind wishes
Ryan
Hi Ryan - -thanks - there are a few new dialogs that lag a little,(or occasionally a lot, but I think those are fixed now) compared to V5. If you run across any where this is enough to be annoying, please point them out, there may be more room to tune them up.
