Under the BoxEdit tab - When highlighting a value in the position section - I no longer have the option of copying or pasting values - I found this useful in Ver 6 so that I can match object positions with min / max values.
Thanks for your time
Hello - as far as I can see copying and pasting numbers BoxEdit between fields works in V7.2. Does nothing at all happen for you- no paste?
For me - If you double click the field to highlight value - as soon as you right click - cursor moves to end of line and copy option is not available
