BoxEdit Improvement Request
It would be really helpful if the uniform resize option could be made to work on any of the three size cells. Currently, when activated, one can only manipulate the size in X which is quite limiting. Also, I would really appreciate having the ability to initiate changes in the panel with spacebar/enter. It’s very inefficient to have to click “Apply” after every change. Thanks!
Huzzah! Thank you! I can definitely see a case being made for that option to exist closer to the actual check box it modifies. I’ll mark this as solved shortly if no one weighs in on the “spacebar/enter” request. Guess I should have made a separate topic for that.
