Have quite a few boxes I want to 3D print. Various sizes. Wanted hinges that require no additional hardware and a latch that functions well.
This is pretty much a typical box that is available all over the internet with a few mods.
Utility Container.gh (130.1 KB)
This required a lot of Solid Unions. My first go was a total disaster. Normally I just power on and let the slicer put things together, but I finally decided to knuckle down and see if I could actually make it work like I thought it should.
First lesson, make sure to have the base geometry clean. No “sort of close” stuff. I started out that way because I created the curves I needed by getting cross sections from an stl file. That really can cause the boolean stuff to go berserk. The next one was a little more insidious.
Previously I would extrude a curve, grab the cap holes component and presto. Yea, no, that is sketchy at best. Sometimes parts would union, sometimes not, sometimes it would deleted pieces. Bizarre at best. What cured that was creating a surface, then extruding the surface. Yea, I am sure some of the Enlightened on this forum know all about that. Problem is not all of us take the time to dig through everything. We sort of learn by doing. Anyway, once I figured those things out, it all came together pretty nicely.
It can stand some cleaning up and probably some optimizing, but hey, it works.
BTW, it now resolves to two pieces, the bottom and the top. Very clean. I did not put any height controls in, I find it easier to just drag the height out to where I need it.
