Boundingbox set to preferred direction
I’m trying to script ‘a boudingbox to certain direction,’ the boundingbox does not direct with a face in the direction of the blue line, it’s not working, what am I doing wrong?
Thanks in advance for your response.
20181012 problem boundingbox correct direction 00.gh (20.6 KB)
20181012 problem boundingbox correct direction 00_re.gh (19.5 KB)
Thank you Rickson!
invalid points to construct the plane
Yeah, shortly after I typed that I found it.
Hm, somehow my script does not work completely.
I was looking for a shorter script, however, this was the only one I achieved successfully.
The theory is of what I want to achieve is a ‘rotate on the floor thing’ and than a ‘climb rotate upwards.’
Do you know one component that can achieve that?
If so, I will try to figure it out how it must work by myself.
Transform Matrix??
Personally i would probably rotate a plane.
Thank you. Yeah, sorry, I cannot handle rotate plane, I never could, but this must then be the moment I learn it.
Sorry for asking.
Ah, indeed, just rotate. What a relief, and thank you again.
:grin: :
