How to bound external boundary surrounding the curves like the attached image.
BoundingBox.gh (4.7 KB)
Why?
Or, why not also the green parts?
If you can answer that question, you will probably be able to solve this yourself…
Hello
I think you have not yet clearly defined the limit of what you really want.
First you have curves aligned with X and Y and now everything is rotated.
If a group of building is aligned and not the other what are you expecting ?
If you have a U shaped buildings, what do you want ?
If a group in one rectangle what do you expect ?
It seems you are after a sort of minimization of aligned bounding box. The criteria to choose 1, 2 3 bounding box could be a ratio of area.
But whatever it is not a so simple exercice for a tool. Human on that are still better.
how did you Rotate the curves use the same reference to create the bounding box whatever u need
Some how achieved this
Now im looking create something like this. L shape around given curve.
bounding problem.3dm (134.2 KB)
Hey,
Check this out:
Script is uncleaned. But it works perfectly.
LBoundary_BVR.gh (53.4 KB)
Cheers,
BVR
