Bounding box Rhino 7
How do i get my geometry out of bounding box in rhino, so that I can edit its shape?
Hi Adam -
I don’t understand what that means - can you be more specific?
If you run the BoundingBox command on an object, that will just create a box that you can delete, move, etc without that impacting what you can do with the original object.
Sorry Wim, I had a brain fade moment, I turned my geometry into a block with a bounding box. all I needed to do was edit the block. thanks for helping.
