Boundary edge settings bug?
In wireframe, I have set my subd boundary edge colors to be a single color, but if I have points turned on then I see a weird mixture of colors instead of my chosen color.
Hi Peter,
Can you provide a small example along with your customized display mode and we’ll take a look? Thanks!
Note this only happens with subds displayed in Box mode, and points turned on. Also I do see it happened in V8 as well.
edge color.3dm (55.5 KB)
wireframePH.ini (14.3 KB)
Hi Peter -
What you are seeing is the control polygon of the object coinciding with the boundary of the object.
You could use the “Hide control polygon” option on the [your_display_mode] > Objects page.
I like seeing the control polygon when subds are displayed smooth. In any case, the color thing is just a little weird but it doesn’t make much difference, so I guess problem solved?
