Bottle model - surface continuity
Hey! I’m trying to 3d model a bottle and I’m having trouble making smooth transition between the main shape and the neck. I did the body by extruding and then cage editing the extrusion and then I wanted to create the top part - which I tried doing first by sweep and then network surface - but both couldn’t be filleted (I wanted radius of 6). I then figured I can draw already filleted curves and network surace them (messy, I know). It looks just how I want it but when I connect two parts the transition doesn’t seem to be completely smooth - the middle part connects nicely but I can see some break near the edges - especially on 3d print. How can I fix this or what would be a “clear” way to 3d model this?
500forum.3dm (820.1 KB)
Where do you want the 6 radius fillet?
you could create the shape with a loose loft, see attached example. With History enabled you can now shape the loft by moving/scaling the source curves.
500forum_loose-loft.3dm (1.4 MB)
here
It’s good to know but in this case I want to have a precise control so the curvature of the arms follows the exact curve I drew which I think I can’t achieve with loft - or correct me if I’m wrong
you can also model a quarter, then you have full control over the shape, and solve the transition with BlendSrf
500forum_quarter.3dm (6.9 MB)
