BooleanUnion Problem
Hi. I am new to the program. I’ve been trying for days now to solve this problem. I am trying to model a ship in Rhino and simulate a ship collision with LS-Dyna. LS-Prepost sees bulkheads as a seperate part so when I mesh the ship it creates independent meshes. I am trying to Join or BooleanUnion for the surfaces but I keep getting errors. Any thoughts?
Welcome
Please upload your rhino / 3dm file.
Just drag and drop it to the text edit / answer field
shipmodel.3dm (675.8 KB)
Hi Steam -
Rhino typically doesn’t allow the creation of nonmanifold objects.
You can try to use the NonManifoldMerge command on these objects. Then extract the rendermesh or create a custom mesh and export that to LS-Dyna.
What file format is being used to transfer to LS-Prepost?
I expect NonmanifoldMerge, then IGES export to LS-Prepost. But the surfaces will probably need to be Stich/join together.
STEP format does not work with Non-manifold surfaces joins.
