BooleanDifference Fail
Why does this BooleanDifference fail - just trying to understand.
bool test.3dm (216.8 KB)
Keith
I see that this file is created in the WIP so I’m changing the category to Serengeti.
Are you running the very latest version? If so, that might explain what’s going on since some trimming bugs were introduced there (though I’m seeing problems in a previous release but that might not mean anything :blush: )
The short answer is that the intersector is failing here.
If you intersect both objects, you will notice that the resulting curve is open across the top cap of the cylinder-ish thingy.
The really weird part is that a boolean union works OK.
You can manually do what you want by using the trim command to trim the objects against each other. Then join all.
Thanks for your help Wim,
If I remove the capped ends ( created in pipe command ) then apply the “cap” command to the cylinder the Boolean difference then works - not sure why pipe cap=flat fails the boolean test in this instance.
Kindest regards,
Keith
Are you running the latest WIP?
6.0.15209.10391, 28/07/2015
That explains it.
尽管采取了有效措施,但是这种情况经常发生,请看下图:
期待新的解决方案
test.3dm (3.9 MB)
Hello- thanks, as far as I can see this is the same case that you posted elsewhere - it is covered by
RH-64895 SSX: partial intersection
