"BooleanDifference" bug
Using this tool, when selecting a group protrusion object, the bug that only one surface is selected like the image and the difference in the enlarged state are a failure phenomenon. When zooming out, re-difference is possible.
ps. I’m a Korean, so I used a translator.
Hello - this should be fixed in the SR 7.5 release which will be available today.
RH-62550 BooleanDifference: Brep face incorrectly selected
Did you fix tool launch failure when zooming in the viewport?
I just updated to the latest release, but it hasn’t been fixed.
Problems occur with polysurfaces made from curve extrusions. Please watch the video carefully.
The modeling file used in the video is also attached.
bug.3dm (134.9 KB)
@pascal Do you mean the Service Release 7.4 or Service Release Candidate 7.5, both available today?
I think Pascal meant the Service Release Candidate 7.5 available today, not the Service Release 7.4 also available today.
rhino_ko-us_7.5.21068.13001 installed but not modified.
Seeing that the file name is 7.5, I think it is correct that version 7.5 is installed.
Hello - yeah, the fix should be in the release candidate, 7.5 not in 7.4. Are you saying that you see the bug in 7.5, still? I’ll check…
yes… T. T
In addition, a polysurface completed with a normal join can be selected normally and becomes a boolean difference set.
However, polysurfaces grouped after extruding with curves are selected as wrong objects as in the video, and the Boolean difference set fails.
I’m seeing this here as well. As soon as the extrusion objects are grouped, the boolean diff fails (and Rhino tries to select the subobjects of the extrusions, when you click them as operands in the boolean operation).
HTH, Jakob
Rhino 7 SR5 2021-3-9 (Rhino 7, 7.5.21068.13001, Git hash:master @ 76e41732e41ab44776e5ac3fa043f38d54440011)
License type: Commercial, build 2021-03-09
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 95Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2021
Driver Version: 27.21.14.6140
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
D:\Dropbox\2D & 3D\Rhino plugins\StereoView.rhp “StereoView”
D:\Dropbox\2D & 3D\GH\elefront421\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\1.0.0\Substance.Win.rhp “SubstanceImporter” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21068.13001
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.9.1.565\PanelingTools.rhp “PanelingTools”
Hello - the developer is working on fixing that for extrusions - thanks!
thank you!
