V5 and V9
made a helix then piped it in v9 as v5 failed was twisty.
bring it back into V5
then trim end to cylinder
cap planar holes (solid cap planar)
select both and select Boolean union
fails.
slide along cylinder to see if shared planar end an issue, try again,
fails.
export the objects
open in V9 try again,
fails.
Rotate the cylinder seam so that it doesn’t pass through the round cap on the helix.
Don’t trim the helix to length before the union - union the complete helix to the cylinder and then trim it with a plane to get rid of the unwanted part. To fill the resulting hole extract and delete the remaining piece of the end of the cylinder and cap the object.
Hi, OMG
I never knew seams had to avoid solids that were to be unioned.
Trim afterwards, its a trick one now stores in the sub conscious, and dusts off, if one remembers, next time.
I wish when launching rhino a little tip or trick vid appeared, we could soak up such , into the 'ol grey matter, .
VideoReDo does such opening vids.
Reminds me I must find the training videos that came with Rhino4, and play them from CD or stick, if I can find the stick.
or wherever they are on the internet now. I asked the other day, must look to see answers.
I love to learn, Need time and to find the mini vids.
