Independent of Rhino’s limitation in this case, I don’t understand why you are modeling that shape in this way. It makes a good example to highlight the limitations of the current statue of the tools, but what are you modeling and why is this the approach being used to make that shape?
In exploring this, I found a curiosity I don’t understand:
I deleted your green objects, then Exploded the red polysurface and joined it again.
Then I used Array to made a new row of 5 polysurfaces 3 mm apart like the original green ones.
This group of polysurfaces Boolean as expected.
So far, I can’t figure out why your green ones don’t work.
@Charles: Lose the tone.
I understand the frustration.
It isn’t helpful in figuring out the problem.
At this point I do suspect a bug but I don’t think it is in the Boolean specifically.
I described how I replace your objects using your own, that did not exhibit the Boolean problem. So far I can’t figure out any difference between your original red polysurfaces and the new ones I created by Arraying your green one.
Precisely, how did you create the red ones?
My guess is there may be a bug in the tools you used to create the red objects.
As you know, to fix a problems, we have to be able to repeat it.
I deleted the polysurface next to the red one, the copied the next on over to replace it using the Center osnap between two other polysurfaces to keep the original spacing.
This group with the single replaced polysurface does Union as expected with no other changes.
That narrows down the problem to that polysurface.
Next, I isolated it, Exploded it, ran RebuildEdges on it’s surfaces, and Joined them back together. This “cleaned up” polysurface also worked fine for the Union.
Which tone are you talking about?
In any case: John, I apologize, sorry - I think the ‘tone’ is just a misunderstanding.
On the other hand, I understand your frustration.
In the beginning, there is a profile curve.
This curve was used with Revolve.
ArrayLinear created all copies, regardless which color.
The red color was only assigned to show the offending object, no other changes.
The same main problem occurs with other similar geometry as well.
John, I tried ‘everything’:
a row of objects, let’s say 20, and begin to bool beginning at the other end
rotate all by 90°
other cplane
scale by 10, 100
rotate by an arbitrary angle
other geometry
bool in groups
bool one after the other
playing with tolerance settings
without the upper flat surface
copy one by one, not using linear array
etc.
etc.
-C-H-A-R-L-E-S-
Edit: Do you know a good workaround to at least get the desired geometry?
That’s very strange.
I gave you two ways I got your model to work.
Try these:
Delete the green one closest to the red.
Copy one of the green ones into the space left by the on you deleted.
Select them all and click BooleanUnion.
That Unions correctly for me.
Undo back to the original, then:
Select the green one closest to the red.
Explode it.
Run RebuildEdges at default tolerance.
Join the results.
That Unions for me too.
For whatever reason, it seems there is a problem with the first green one.
I’m at home on my Mac.
On Tuesday when I’m back in the office, I’ll try it in V6.
If it fails there, I’ll see if my work-around’s work and get it bundled up for the developers.
Note that fixes to the code based on a specific example will not (likely / necessarily / always) fix problems in other situations. If you have other situations that fail, you will have to post these as well.
hey Charles i dont even want to say how much time i spent on one of your examples and did not succeed i had multiple approaches but always ended up that surfaces did not want to work with comments like non manifold edges found.
you can try with the script placed in this thread Split curves at every intersection it helps you to split each surface with each other, i gave up on it because my computer is about 7 years old, maybe you have a quicker one and can succeed. it will not give up so easy i guess but you have to be patient and let it work through because having appropriate splits is the only thing which still can help you there i believe. after that you have to delete all the unwanted surfaces and join it carefully together. its still a lot of work and no guarantee.
booleans function may also have problems determining which surface shall be joined together with which because you have them stack into each other so much that some surfaces get split over several other surfaces and rejoined at completely different intersections… i dont want to make any theories but thats tough stuff. to cascade shapes intoo each other having them touch on one curve only till they get rejoined is always pushing booleans to its limits, i would suggest finding a better workflow for this.
If that is your objective why not just draw the centerline of the toolpath and offset it on both sides by the tool radius. You can then add a 180 degree arc on each end and use hatch to indicate the area that has been machined.
Thanks for sending these. I’ll put them on the list and see if I can fix them next time I work on booleans.
The problem seems to be caused by the way we are handling the seams on the revolved caps. In your first two examples, NoBool and NoBool2, if you explode, delete everything but the cylinders, and cap, then you get the same shapes and can boolean the result in V6 (didn’t try V5).
