Esteban1
(Esteban)
1
Hi all, I have this boolean toggle to give either 0 or the rebar diameter.
But I wonder of I can make disappear the bar in tekla too, when I switch off the buttom.
The highlighted in blue rebar is the one I want to disappear:
(Switch ON)
(Switch OFF)
(Stream Filter)
Set the Boolean toggle to cut off the shape of the bar instead of the size. Also enable Remove when input is empty.
Esteban1
(Esteban)
3
Thank you, Oskar.
I will take a look on that.
Esteban1
(Esteban)
4
Oskar, It worked perfectly fine.
Thanks mate.
