I’ve tried to simplify my issue, I may need to add more detail if I’ve over simplified my question.
Is there a way to Boolean toggle between making a mesh visible or not visible (visible may be wrong terminology. active or inactive) ?
2 simple methods with Stream Filter or Stream Gate
Ah I didn’t put the mesh in and out!
Is there a way to toggle between multiple meshes. 3 or more?
Thanks btw!
Put all your meshes toghether with a merge component, everything with preview disabled.
Then use list item and use a integer-numbers slider 0 to intem count -1
I’ll try explain another way.
If I had 3 meshes. Can i make a list naming each mesh. Then select one of the meshes to activate it. A multiple choice between 3 rather than a binary choice.
