I have 3 very similar objects created by sweeping the same section on 3 different cubes. I am unable to Boolean them, even though they do not appear to have any problems. The middle example I used the Trim tool to break them down but this created many naked edges which I have no idea how to repair. The third example, I exported to Form Z and Boolean Split in Form Z then used the Boolean Union tool in FZ, it all worked fine. I exported and imported the object to Rhino. It appears to be a lot cleaner and is a closed solid poly surface. Is there anyway to use the Rhino Boolean tools without going to Form Z?
_intersect
both profiles (red curves)
_polyline (with project) (cyan curve) from point-snap to point snap on red curves
_trim in planar / orthogonal view
Thanks Tom for your help. All these profile bend on the same plane. I am not sure I understand your process. If I am correct I need to do the following:
use intersect tool to generate the red curves
snap a curve to points of red curves
trim in ortho view
join
merge all coplanar faces
I will give this a bash tomorrow morning, thanks for your help.
