Hi. Any idea why this boolean is not working? (the rials for the pipes are coming from intersections, should be accurate).
Might be the tolerance ? And if so? how to change it ?
Thanks!
Thanks!
Hello - most likely, the seam on the pipes is lying right on the larger surface. Post a file with the surface and one or two pipes,
I am not sure I am understanding here the scene
The pipes are working now…when i change the tolerance of the file. I just cant fillet them…the fillets get separated from the surface.
pascal.3dm (1.0 MB)
Thanks
