Boolean intersection set is empty
I’m trying to apply voronoi on a stool and then pipe the brep edges. However, when I try to do solid intersection, the error is coming up saying that the boolean intersection set is empty. And the multi pipe is also not working. Can someone please help solve this.
Stool.3dm (295.9 KB)
stool2.gh (23.5 KB)
Check your rhino tolerance settings. If it’s 0.1 change it to .001, then close rhino and try again.
I think recompute is enough.
Life saver!
Solved!! Thank you so much!!!
