Trying to boolean uinion and got this error. I have no idea what this means or how to solve it.
Breb_invalid.3dm (1.1 MB)
Rhino polysurface object is not valid.
Line points are coincident.ON_Brep.m_C3[308] is invalid.
I fount the bad part and solver the problem by rebuilding.
The phrase “Line points are coincident” means the endpoints of a line are at the same location. That means the line length is zero and Rhino considers it to be invalid. That line is used as an edge definition which makes the edge invalid.
To find where this invalid edge is, you can use ExtractWireframe and then SelShortCrv .001.
You won’t be able to see the lines because there too small so while the short curves are selected turn the control points on so that they are displayed.
This is a very common problem in Rhino and often Rhino won’t warn you that the problem exists.
I routinely check the validity of polysurface edges with this macro:
extractwireframe pause
selnone
selshortcrv .001
copytoclipboard
undo
paste
The purpose of the last three lines is to get rid of the other wireframe curves that you aren’t interested in.
Thanks so much Jim. This is great information for the future.
