Boolean Difference
Is there a way to subtract a body inside a larger body using boolean difference or another tool? It seems to want an intersection to work but the body inside does not intersect.
Hi Ben -
That’s correct, the Boolean operations require intersections.
There are tricks to turn non-intersecting objects into an hollow object but that falls apart again with downstream operations.
Why would you need to do something like this?
I need the interior to create a space of the interior object to then use that space for other commands. There is a tool in solidworks that does this very easy, i dont know why Rhino does not have this function.
This example has been posted by @Helvetosaur some time ago:
boolean_union_void.3dm (85.3 KB)
