The boolean difference don’t work correct inside the Visualarq Grasshopper definition, it use only the first objects from list and not all.
Hi @bjornsmolarek, the VisualARQ GH styles don’t work well with lists of objects inside referenced geometry params. But they work using a “Data” parameter instead.
Try to connect the “DS” and “D11” referenced objects into a single “Data” Parameter. Do right-click on that Data component and select “Internalise data”.
Let me know if that works. Otherwise, please share the gh file so I can check if there’s any workaround.
