Hi folks!
I have a python file with classes and a certain point I’m createing the model() method that takes care of the modeling in grasshopper. It’s a very simple representation of an apartment with a balcony.
After some tries, i find out that he indented block which starts with
if self.balcony == “Half-inpandig Balkon”:
should be the problem.
I tried a lot but didn’t find a solution.
Can you please help me with it?
The problems lays in the Boolean difference or union: I’m pretty sure about it. Thanks in advance!
def model(self):
apartment = rs.AddBox([(0, 0, 0), (self.width(), 0, 0), (self.width(), self.depth(), 0), (0, self.depth(), 0),
(0, 0, FLOOR_HEIGHT), (self.width(), 0, FLOOR_HEIGHT), (self.width(), self.depth(), FLOOR_HEIGHT), (0, self.depth(), FLOOR_HEIGHT)])
# balcony measurements - CAUTION! for now I'm using dummy numbers.. in the future I'm going to extract it from a database
b_width = 2
b_depth = 1.5
b_height = 1.1
b_thickness = 0.1
offset = 0.2
# balcony modeling
b_box_1 = rs.AddBox([(0, 0, 0), (0, -b_depth, 0), (b_width, -b_depth, 0), (b_width, 0, 0),
(0, 0, b_height), (0, -b_depth, b_height), (b_width, -b_depth, b_height), (b_width, 0, b_height)])
b_box_2 = rs.AddBox([(b_thickness, b_thickness, b_thickness), (b_thickness, b_thickness-b_depth, b_thickness), (b_width-b_thickness, b_thickness-b_depth, b_thickness), (b_width-b_thickness, b_thickness, b_thickness),
(b_thickness, b_thickness, b_thickness+b_height), (b_thickness, b_thickness-b_depth, b_thickness+b_height), (b_width-b_thickness, b_thickness-b_depth, b_thickness+b_height), (b_width-b_thickness, b_thickness, b_thickness+b_height)])
b_final = rs.BooleanDifference(b_box_1, b_box_2)
balcony = rs.MoveObject(b_final, (offset, 0, 0))
# volume to subtract for half-inpanding balkon
# 3.2 because it's bigger than FLOOR HEIGHT
# b_depth/2 because the volume to cut has to be in the center of the apartment
volume = rs.AddBox([(offset, 0, -0.1), (b_width + offset, 0, -0.1), (b_width + offset, b_depth/2, -0.1), (offset, b_depth/2, -0.1),
(offset, 0, 3.2), (b_width + offset, 0, 3.2), (b_width + offset, b_depth/2, 3.2), (offset, b_depth/2, 3.2)])
# rules for apartment models - the model i outputted with the links entrance on the north side
if self.floor_n == 1:
final_b = None
if self.function == "Wonen":
if self.balcony == "Half-inpandig Balkon":
if self.position == "Hoek":
volume_m = rs.MoveObject(rs.RotateObject(volume, (0, 0, 0), -90), (0, self.depth(), 0))
else:
volume_m = volume
final_a = rs.BooleanDifference(apartment, volume_m)
else:
final_a = apartment
else:
final_a = apartment
elif self.floor_n >= self.n_floors - 1 and self.position == "Setback Hoek":
if str(self.unit) == "2.7":
t_width = 2.09
else:
t_width = 2.0
t_height = 1.5
t_offset = 0.34
terras_box_1 = rs.AddBox([(0, 0, 0), (t_width, 0, 0), (t_width, self.depth(), 0), (0, self.depth(), 0),
(0, 0, t_height), (t_width, 0, t_height), (t_width, self.depth(), t_height), (0, self.depth(), t_height)])
terras_box_2 = rs.CopyObject(terras_box_1, (t_offset, t_offset, t_offset))
final_b = rs.BooleanDifference(terras_box_1, terras_box_2)
final_a = rs.MoveObject(apartment, (t_width, 0, 0))
else:
final_b = rs.MoveObject(rs.RotateObject(balcony, (0, 0, 0), -90), (b_depth/2, self.depth(), 0))
else:
volume_m = volume
final_b = rs.MoveObject(balcony, (0, b_depth/2, 0))
elif self.balcony == "Uitpandig Balkon":
if self.balcony_pos == 1:
final_b = rs.MoveObject(rs.RotateObject(balcony, (0, 0, 0), -90), (0, self.depth(), 0))
elif self.balcony_pos == 2:
final_b = rs.MoveObject(rs.RotateObject(balcony, (0, 0, 0), -90), (0, 2*(b_width+offset), 0))
else:
final_b = balcony
else:
final_b = balcony
final_a = apartment
else:
final_a = apartment
final_b = None
return rs.BooleanUnion([final_a, final_b]) if final_b is not None else final_a
