I’m having issues with all the objects I’m producing. When I extrude, patch or boolean difference the result is always glitchy with wrong surfaces. They’re not bad objects and I’ve tried moving my things to a new file, it doesn’t work still. Ive added an example of what happens when I try booleaning difference these two cylinders. Please help I have a submission in a couple of days.
too far from origin maybe? also can you post the file? I don’t see that issue here.
Following Diego: Far from origin Objects Too Far From the World Origin [McNeel Wiki]
To upload a .3dm file drag the file to where you type a post, or click on the vertical arrow icon above where you type.
Hello, yes that was exactly the issue thank you so much
