Boolean Difference fail yet intersect is good it seems?
V5
Boolean Difference fails, grey object into brown. , I check intersect and all appears good, have I missed something ?
both are closed polys details tells me.
made with Pipe command 0.01 to 0.001 then boolen union the result.
Boolean Difference fails.3dm (529.1 KB)
Cheers
Steve
your tolerance is 0.001, which is too rough for this kind of detail:
If you change to 0.0001, the Boolean and Intersection will be better
