Hello. I’m trying to separate one piece from another using the Boolean difference, in this case, two metal rings. The thinner ring is applied using the Flow command. When I do this, an edge remains, even after adjusting the baseline, object, and target line lengths before Flow. The command should separate the purple ring into two disconnected parts, but this detail remains. Where am I going wrong?
You don’t need to make such a complicated shape if you’re just splitting it in two - just use a box - or make two extrusions
(I imagine the problem is happening because the curve is a little too short and leaving a small gap where the end points don’t touch)
If the edges of the smaller ring intersect, a Boolean difference error occurs, but I only used the smooth ring for illustrative purposes; the element I want to extract is more complex than simply separating it into two parts.
Then we probably need to see the actual part and a file - there are lots of reasons why booleans fail: Boolean Frequently Asked Questions [McNeel Wiki]
This is why there’s “boo” in boolean ; )
flow_booleandiference.3dm (218.8 KB)
I sent a simple file where I try the same procedure. If the borders intersect so there is no space, the boolean difference throws an error.
Yes, these edges are not going to boolean reliably:
You would want to rebuild this as a hollow cylinder - in many cases I would use DupEdge to rebuild the geometry, but because your edges overlap like this, you wouldn’t even be able to make a clean object with them without some repairs - which is why we asked to see your actual file so that we don’t waste troubleshooting something that’s not entirely relevant to your problem
The simpler your object is, the more reliable your boolean operations will be (the main body of your ring for example, has more isocurves than I would like to work with which suggests it’s more complex than a shape like this needs to be):
flow_booleandiference.3dm (452.0 KB)
Hi James,
As stated above, the boolean is failing because the cutting ring is inaccurate. That doesn’t have to be, regardless of the complexity of your objects. Here are the steps you need to take to get an accurate band.
- Create a cylinder that accurately defines where the outer face of the cutter band is to go.
- Create the rectangular profile of the cutter band and use the extrude command (not the gumball) to make the long flat box. When extrude asks for the distance, type
lengthand click on one of the outer edges of the cylinder. - Move your more complex object into the box.
- Use FlowAlongSrf (not Flow) to flow your complex object onto the ring. For the base surface sub-object select (ctrl-shift click) the top face of the box and for the target surface sub-object select the outer face of the cylinder.
- Your complex object should now be accurately placed around the ring without misaligned ends and can be used for the boolean difference.
If the boolean fails, do a test flowing the simple box instead of the complex object to confirm that the box will split the ring and therefor that the issue is now with the form of the complex object.
HTH
Jeremy
