Boolean command
It takes more than half an hour to do Booleanunion or Boolean2object
(Not server)
System: i9 , 64gb ram, a4000quadro
aa1
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Commercial, build 2023-09-05
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 11-8-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 526.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-8-2022
Driver Version: 31.0.15.2686
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\ToolPanelR7\1.0\ToolPanelR7.rhp “ToolPanelR7” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\export_STL.rhp “STL Export”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
How many separate objects are your trying to Boolean?
There are two objects
There are numerous possible reasons the Boolean command is taking a long time. Without a .3dm file with the geometry it is difficult for anyone to diagnose the problem.
The wire display of the gray object on the right looks strange, if they were shapes trimmed to each other to form a complete closed shell, I would expect to see the intersection curves between each “lozenge” - which I don’t see. But it’s difficult to tell from an image.
I export just two objects and exported file size is 54 mb , it’s nice now . I understand that If I combıne all of parts dragon , File size is problem high detail 500mb
Why don’t you shrinkwrap everything in Rhino 8 BETA?
I don’t it for main object herringbone scale .Using shrinkwrap for high detail poly count is not enough or high detail poly detail is lots count for rhino
