This workflow was very problematic due to 3ds max instability/unreliability. I spent many dozens of hours failing.
I am wondering if something similar can be achieved in Rhino. The biggest question is how to set up the boolean components.
The topographic mesh can be created with Delauney and converted to Polysurface.
The path with a tapered ‘bevel’ is where I’m lost.
– How does one create the purest boolean path component given that the path outlines have varying elevations. Sweep/loft/offset/ribbon offset/GH?
– Can it be done as a single component, or would it have to be multiple booleaned together?
– How does one create the path taper?
– Can the boolean landscape take on the material id of the bevel operands?
If you have any ideas or thoughts about the above, would be greatly appreciated. This is very useful for landscape design.
If you can create the path centerline, you should be able to sweep a tapered rectangle as a profile and use that as cutter and filler.
You might want to attach a file.
Hi Wim,
Thanks so much for your advice; I will try it. I just want to clarify a few things
Do you mean to sweep the tapered rectangle; then convert that to mesh as well for boolean with the Mesh topography? Or leave the tapered cutter/fill as a polysurface for boolean with mesh topography?
With this tapered sweep workflow; it seems like that the separate parts of the path would need to be created as individual components instead of a single solid for boolean. I’m not sure how 3ds manages its single ‘bevel’; but would you recommend I boolean the individual polysurfaces together before attempting boolean with the topography? Or to do them separately?
In this image, you can see the editable spline and the landing vertices which have been raised to various heights. Also note that it’s not one linear path; bur rather an outline of many path segments; raised to various heights. This is what made me wonder how they make it into a single solid in one modifier.
If you increase the bevel outline to an extent where the geometry overlaps, it ‘uncaps’.
In Rhino; sweep, loft and planarsrf can combine to achieve something similar it seems; but as seperate parts which are used together as boolean operands.
Hi Jeremy - can you please post your file, even a simplified version of what you are working with, or send to tech@mcneel.com, with a link back here in your comments?
Sorry, I didn’t know what file type you wanted. 3ds has it’s own internal processes which get converted to meshes when exporting.
I’ve attached a DWG and 3dm with a mesh and curve.
