Bool marking
After performing bool operation I’ve noticed such a mark. What could it be?
Bool
You should be able to select it, then check in the dot panel what the text is. It is a warning or problem area.
Right, the message is “Intersection curve ends at a naked edge.” Is there any problem with the volume?
Hard to say without a 3dm containing the objects used, but this can happen when you’re trying to use boolean operations with non-closed polysurfaces. I wouldn’t be surprised if there are other cases that cause this message.
OK, Thank you for reply. I won’t be investigating this further, as there seem to be everything OK with the volumes.
