I have an animation where is a block with an animated sequence. If I insert a few ticks at the beginning of the animation, than the later shown block keyframes are not moved like all the other keyframes.
At this place first an idea - could blocks not get an own representation at the time line? For example if I select the block at the scene than at the time line a marker could show the range of the block keyframes. Here a raw example - the blue range is from the block.
So, if ticks are inserted than the block keyframes should be moved too or the user should be able to select the block and move the shown range.
At the moment I must go in block edit mode, select all keyframes and move them one by one .
Best-
Micha
