Bongo Easing
How can I turn off automatic easing by default? Or turn it off on multiple objects and multiple keyframes?
I find automatic easing to cause unwanted results for the type of motion I’m after and turning it off on every key frame is cumbersome.
Any solutions?
Unfortunately there’s isn’t a way to turn it off by default.
You can turn the auto easing off on multiple objects and keyframes at the same time, by selecting them all in one go in the Keyframe Editor and unchecking the check box.
How can I do this without having to go to each keyframe? I want to turn it off for all objects AND all keyframes.
  1. Select all object you want to edit.
  2. Open up the keyframe editor.
  3. Make sure all objects are selected in the keyframe editor (they should be marked blue).
  4. Select all Keyframes (click and drag across all the keyframes at the bottom of the keyframe editor)
  5. Go to the setting you want to uncheck and uncheck it. It should remove the checkbox from all selected objects and all selected keyframes.
That works! Thank you.
I was missing the fact that you are able to select multiple keyframes in the timeline by window drag selection.
Multiple keyframe selection can also be achieved by Ctrl clicking (add to / subtract from selection).
It is not only available in the KeyframeEditor but also on the Timeline.
マクニールさん
ライノオプションで「リニア」を選択しているのですが
「自動イージング」が有効なために、実質「リニア」でないようです。
オブジェクトに「移動・回転」の両方ある場合は、オブジェクト単位でしか選べません。自動イージングがOFFされない為、「リニアにできていない(バグ)」のように思います。
Dear McNeel
I’ve selected “Linear” in Rhino Options, but
because “Auto Ease” is enabled, it doesn’t seem to be truly “Linear.”
If an object has both “Move” and “Rotate” properties, you can only select them on a per-object basis.
Since Auto Ease isn’t turned off, it seems to me that it isn’t working linearly (a bug).
Is it possible to make improvements?(KAIZEN)
In most cases true linear interpolation for animations is very undesirable and that’s why Auto Ease is not turned off by default. In those cases where it’s needed to be off one can always turn it off in the Keyframe Editor.
If an object has both “Move” and “Rotate” properties, you cannot change them all at once. You can only select them on a per-object basis.
