If you change an objects name in the Rhino object properties window, it doesn’t update the Bongo Animation Window Hierarchy until you close and re-open the BAM Window
Is this normal ?
Is this normal ?
Thanks for the bug report. Unfortunately this is a known issue and will not be fixed in Bongo 1.0.
Have you tried using Bongo 2.0 - which is just about to be released?
