For "Bongo Render Animation"
If I understand well,
Renderers as RhinoRender or Brazil may work in two ways:
with an automatic delay, as before this release (“Render frame delay (s):” set to 0
or with a fix delay set by the user
When using just Neon (without Brazil), I still have to
set the Target renderer to Viewport Display
and set the Render frame delay to a no null value (no automatic delay).
Yes, you’re right.
The Render frame delay (s) is the same as View capture delay (s), it’s just made available for all renderers, so we had to change the name.
I have just had to undo the Service Release 5 download as my system started to glitch quite badly, Windows 7, 64bit. My computer returned to its normal level of function once I did a systems restore to before the Bongo Service Release 5 down load.
Hope you find this info of use.
Shane
