hey everyone. I meet a mistake in my grasshopper. When I create the bone structure by using the Minimal surface, I don’t know why I layout some many meshes as result. I think it should layout only one mesh. I checked many times but still don’t know where is wrong. could anyone help me? thank you.
Here’s your file updated to use the current Kangaroo. stretchedfabric_k2.gh (13.8 KB)
It runs in a few seconds instead of minutes.
I’d also recommend generating your input mesh a bit differently. Here you start with a lot of triangle ‘fans’ and long skinny triangles, which don’t relax so well.
If you are starting from a Brep, try using the detailed settings when meshing it, and setting a minimum and maximum edge length to get a more uniform edge sizing.
