Boltgen BSP thread
Hello, I love the plugin boltgen, for metric threads I use i very often, also for 3D printing it works very nice!
Now I need to print 3/4inch BSP. therefore I command boltgen>>english>>inside threadcutter and nut, and then I searched for 3/4 and found this:image
the thread I need is 14, so I chose 3/4 - 16 (closest to 14).
Both diameter and thread are wrong.
the thread is 16, but I need 14, I chose 16 so that’s obvious.
the diameter is also wrong: it should be close to 24mm.
Probably I use the boltgen wrong for this matter, can someone help me out?
Hi @Baasab,
I’m afraid Boltgen doesn’t produce BSP threads. You should be able to download a BSP CAD file from these people: https://www.mcmaster.com/
You need to log in to their website to get access, but it is a popular resource here. Don’t forget there are two types of BSP: parallel and tapered - if you are mating with an existing connector you need to know which type it is.
HTH
Jeremy
HI Jeremy,
Thanks for the tip, nice site for downloading lot’s of stuff.
However I can’t find the ¾-14 thread as a model. Am I searching wrong?
Hi @Baasab,
No, if you just want the thread then you will need to download a threaded object and extract the thread from it. You may need to array/trim the thread to extend it to the length you need. Assuming you want a parallel internal thread then this might be a starting point: McMaster-Carr
HTH
Jeremy
Thanks, I modelled it myself. Now printing a testmodel to check if it is right.
If you need a model for ¾-14, let me know😅
