In the early 1910s and 1920s, America experienced one of the most spectacular—and at the same time deadliest—eras in motorsport history: board track racing. On gigantic ovals, known as “motordromes,” pioneers raced against time and death on machines like the Indian 8-Valve.
The Tracks: Giants of Wood
The racetracks consisted of millions of pine or spruce planks laid on their edges. With steep turns of up to 60 degrees, these tracks were designed to harness centrifugal force to enable speeds beyond imagination. A tire blowout in this situation was almost always a death sentence due to the G-forces at play.
The Machines: Pure Power
No brakes & no clutch: Every gram of weight was saved. Braking was achieved by short-circuiting the ignition or, as with my model, by lifting the intake valves so that compression collapsed; starting was done by pushing or using a tow rope.
Radical Technology: The 1,000 cc 8-valve engines were technical masterpieces that catapulted riders to over 190 km/h—on tires barely thicker than those of a modern bicycle.ycles like the 1914 Indian were highly efficient, uncompromising machines:
The Gladiators of the “Murderdromes”
The riders were superstars whose only protection consisted of a leather cap and a wool sweater. Heroes like “Texas” Cyclone Taylor and Charles “Fearless” Balke were celebrated for their courage as they raced for their lives through thick oil mist and swirling wood dust. To counteract the dust and oil sticking to their throats, the riders often chewed on lemon slices to stimulate saliva production.
The risk was ever-present: the oil from the loss lubrication system turned the tracks into mirror-smooth traps, and rotten planks became deadly projectiles. These extreme accident rates earned the tracks the grim nickname “Murderdromes.”
The Legacy
Board track racing disappeared in the mid-1920s. The costs of maintaining the wooden tracks were too high, and the risk to riders and spectators was no longer acceptable. Yet the machines—like my model of the 1914 Indian—endure as mechanical monuments to an era when courage knew no bounds.
Key technical specifications, based on the 1914 1000 cc (61 ci) factory V-twin engine (Engine No. 74E 674).
Technical Specifications: 1914 Indian 8-Valve Board Track Racer
Engine Type 42-degree V-twin
Valve configuration OHV (overhead valves), 4 valves per cylinder
Displacement 998 cc (60.92 cubic inches)Bore x Stroke 82.5 mm x 93.6 mm (3.25" x 3.68")
Power approx. 15–20 hp (depending on tuning and fuel)
Compression Ratio approx. 5.5:1 (very high by the standards of the time)
Carburetor Schebler Model L (racing version)
Ignition Bosch high-voltage magneto
Lubrication Flood lubrication (hand pump on the tank + drip lubricator)
Drive Direct chain drive (no transmission, no clutch)
Frame “Keystone” type (engine is load-bearing element)
Weight approx. 115–125 kg (ready to ride, extremely lightweight)
Top speed approx. 115–120 mph (approx. 185–195 km/h)
For my reconstruction, I used the 1914 Indian 8-Valve factory race bike—likely the last one ever displayed in nearly original condition—which was exhibited at the Guggenheim Museum in 2008 as part of the “The Art of the Motorcycle” exhibition. The bike was sold to a private collector at a Bonhams auction in 2022, and the photos from that auction served as my reference. I hope you enjoy looking at it. Best regards, Rainer
